EU tail lights
Hi, I am elvin from newcastle , UK and I have the EU LED tails lights. I have been trying to achieve the 4 full circle lit on both tail and brake lamp.
After reading much from here, it seems that the wiring and schematic of the EU lamps are still very vague. SO i decided to share my knowledge of the EU taillights.
anyway, here goes.
the EU Taillight's configuration is like this, pretend you are looking at the lotus from the rear and the brakets () are the rings.
EU LED TAIL LIGHT CONFIG
(0) 0) LOTUS (0 (0)
the outer rings have 2 functions, tail and brake whereby the tail is a dim full circle and the brake is bright full circle.
the indicator is in the middle and it is amber in colour.
Total wires from this lamp unit is 4 (tail/brake/indicator/ground)
the inner lamp units have 2 functions only.
HALF a ring for FOG LIGHTS and the center white bulb for reverse.
Therefore only 3 wires from this unit (fog/reverse/ground)
Hope this helps in the discussions
