What is the point of this rear facing rubber bushing on the rear transmission mount? Looks to be for some other application. I assume this could be removed to knock off a little more weight.
https://www.innovativemounts.com/ProductDetails.asp?ProductCode=60950Does anyone make full rubber engine mounts rather than the manly mounts that might be slightly less stiff but still stiffer than stock?
Thanks, but how does the "60A Street (Red)" compare to the stiffness of the manly mount inserts? Is it softer or harder? All urethane mounts I have used in the past are always stiffer than rubber.
