1 - 10 of 10 Posts
$SOLD
willing to split up the rims and tires if someone is buying 4 rims or 4 tires (as in i wont just sell fronts or rears.. must be purchased as a set of 4)
must be local in southern california , my zip is 91387
Like new, only 1,800 easy miles on this setup. Zero curb rash or imperfections.
Matte black XXR 527 wheels
16x8, +20mm offset
205/45/16 Toyo Proxes R888R
17x8.25, +25mm offset
235/40/17 Toyo Proxes R888R
Included:
Custom machined 1-piece 7.5mm hubcentric aluminum wheel spacers for the front (to clear the front brake caliper) and aluminum hub rings for the rear
16 x BMW black wheel bolts (extended bolts to be used with spacers)
This setup is beautiful and aggressive looking. You need -1.5* to -1.8* camber in the front for a proper look and fitment. Rear camber is irrelevant, whatever you prefer will work.
These are not that much heavier than stock base wheels (16/17 non-sport package wheels with Advan AD07). I weighed them prior to install:
stock front wheel + tire 34.2 lb
XXR 527 + tire 38.2 lb
stock rear wheel + tire 43.2lb
XXR 527 + tire 44.9 lb
Entire setup cost $1600. Priced at $1000 picked up.
1 - 10 of 10 Posts
