1 - 2 of 2 Posts
Getting ready to join the lotus family. I want to make sure that all recalls have been done. But I can't find a simply list of recalls. I'm buying 05 elise.
Oil lines
Shifter
Is the oIL coolers recalled?
Is the radiator a recall?
The connectors at the oil coolers were part of recall.
Not the coolers. Not radiator (but we don't trust anything no all aluminum.)
There was a shifter replaced on early cars, but not, iirc, a recall.
Then, there's this:
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
7. Rear toe-links can loosen and break with disastrous results. You can check tq periodically, or use Nordlock washers. Best is conversion to better engineered brace, such as BOE’s for one example.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
10. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
10. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. are wildly expense when purchased thru Lotus.
Plus:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
1 - 2 of 2 Posts
