This Big Winged Monster Is The Most Extreme Lotus Elise We've Ever Seen
I recently fitted a lotus to my wing rotfl
Great story! I love that you drive it daily, and hope you do well in your competition.This Big Winged Monster Is The Most Extreme Lotus Elise We've Ever Seen
rota gtr 17x9 et25 pcd 108 with 35mm hub adapters to push them to et-10, its about as wide as you can go running wide rubber on the back, I can go wider on the back and run 285 182 wheels if i wanted by running a higher offset/thinner spacer, but for the power im making 255 tyre is enough and i wanted a wide diffuser undertray to maximise the low pressure zone underneathHardcore! What wheels are you running in the rear?
this lotus really needs to see pikes peak in its lifetime :up:This Big Winged Monster Is The Most Extreme Lotus Elise We've Ever Seen
