MY12 running changes, also carried into MY13
- VIN .. CH_10630 on; Door lock/latch mechanism, identified as w or w/o door lock pin changes (i.e. MY12 later half of production) also changes to door trim, inner water shields, wiring harness etc because of lock change.
- Interesting for those having trouble with adding mirror fold switch: along with the Door latch change was a wiring harness change due to look mechanism, this explains the shorter mirror pig tail on harness.
- VIN .. CH_10452 on; 6-Spd Sport Ratio Transmissions, all gears sets changes; mid production.. don’t know what changes is but new is backward compatible, so not gear ratios or geometry, could well be a material spec change
- Battery Box cover; under carpet - early, outside of carpet w/ carpet cutout – later models. No VIN number listed for change.
- Steering Wheel , more ergonomic style added after 1st few cars, no VIN reported (at least GP Edition have old wheel style, due to using special edition wheel based on old form)
- Addition of dead pedal on first of prodcution, then remaoval again (again may be a GP Edition item only)
MY13
- Removal of Aluminum Door sill
- Rumor of using cheaper floor mats, without medallion "Hand Built .."
