1 - 6 of 6 Posts
Saffron Yellow is Lighter
Is there any wire on the Elise that is hot (+12V) only, while the engine is running? Running or cranking should be alright as well. I just dont want a voltage source that is hot when the ignition is on and the engine is not running or cranking. I have not looked for a tach wire or lead yet but that might be one option?
Thanks
You can use the fuel pump power. It is on briefly when you turn on the ignition then turns off once fuel pressure is built. I use is to run the water pump for my IC as the manufacturer of the cooler suggested.
Later,
Eldon
use a 'tap-a-fuse" in the fuse box under the passenger airbag area. this is where i derived power for my hard wired radar detector. radar only turns on and off with "accessory" power from ignition.
Later,
Eldon
That is actually a great idea. I'm using it to run the IC pump and fan as well. I was going to build a delay circuit which will start the delay once the motor starts and having it hot for a couple seconds won't have any effect on my desired results. Thanks for the idea.
+1
Same thing I was going to suggest.
1 - 6 of 6 Posts
