1 - 7 of 7 Posts
As stated, looking for good Lotus ignition module for my 91 SE. Don't need the coil packs. Thanks
Look up Wells Ja1149. think autozone has them quite expensive though. Rock auto for 157.00 U.S. look for WVE 6h1131.
How is this different from the D1927 module. Most of these set a code 41 on the esprit.
The only thing i can tell you is that the WELLS JA1149 is the one i used and there was no check engine light. We used it on a second esprit and there was no check engine light as well.
so correct me if im wrong, this module is for an Impulse Trubo, and also the same one on the Lotus Elan M100.
i know its the same as the impulse turbo. no idea about the elan. Rockauto has a return policy i believe. whats the worst that can happen? If you do get it just remember to use the thermal paste between the coils and the module.
1 - 7 of 7 Posts
