1 - 18 of 18 Posts
The Evora's first name / code name was Eagle and as I look around my car I've found the Eagle name in a few spots and wanted to share.
1262023
1262022
1262021
Very cool, but how does the third pic denote Eagle? I'm old, so maybe I missed it?
San
Yep, was inside the rear quarter panel when I had the sub out also.
Interesting. Eagle=Evora aside, my front bar did not have that label nor those specifications.
@friss Do you have calipers? Can you verify that your bar is really 24mm? All the ones that I have every seen are 23mm.
Cool. Thanks for sharing that. I remember back then hoping that Eagle would not be the actual name.
San
It doesn't say Eagle but it is labeled as a sample unit that I assume was for testing purposes.
I do have calipers and I'll try and get a measurement soon. These pictures were from a couple months ago when I had the car in a more disassembled state.
Have that one too..
I haven't come across that one yet though the sub box itself does have another sticker that I always forgot to grab a picture of. Cool to see it live on in later cars.
I replaced the single DIN alpine with a double DIN in my 2011 Evora, and the black-out plate under the stereo says Eagle as well. I didn't find the Eagle designation on other parts I removed (to do the stereo install), but it was on that black-out plate.
Discussion Starter #10
Confirmed the front bar is 24mm, the rear is 22mm. So seems like both were bigger than production sizes.
2005 Elise LSS Saffron Yellow
Elige development names seem to be race courses - Monza, Croft, etc. I didn't find any obvious sources for the Eagle name from that pool....
I wonder if that's going to make getting new bushings difficult when the time comes.
So this is pretty astounding. It has profound implications for the few of us that run competitive events with tight rulesets. I am allowed 1 sway bar substitution, but not both. If there were alternative sizes produced based on build date, it opens up many more combinations to test. Any additional roll stiffness is welcome.
So down to brass tacks, where did you measure diameter?
donour
Discussion Starter #16
Went out and got some pics of the measurements. Rear pretty consistent though I couldn't get up against the bottom of the bar due to the defuser.
Rear
1263296
1263295
Front was a bit harder to get a measurement that wasn't convoluted. When up against the bottom cover it measured the smallest but elsewhere on the bar towards the endlinks was 24.
1263297
1263298
1263300
1263299
1263301
The bushing look fine from what I can see of them (and as I understand it this car spent a lot more time sitting than moving) but something I'll have to look into at some point. Hope this helps!
Illegal Alien
Did this go anywhere?
I know Lotus Motorsport had larger ARB's, memory says front was 24mm; however, I can no longer find my notes on the diameters:
1269659
I haven’t found any other reference to bars this size. I think the lotus sport front bar is 25mm. Blackwatch racing just teased a new, adjustable bar design.
1 - 18 of 18 Posts
