1 - 7 of 7 Posts
Hello,
I joined this forum to receive some input on the lotus Elise. I am looking to buy an Elise. Would prefer an sc model. I am a car guy. Up till now we have had 60’s era muscle cars and late model Camaros and such. My question is after what research I have done I have found conflicting information on the good and bad of the Elise. I am not talking about the raw performance of the machine. I am more concerned with mechanical issues that may need addressed. Thanks for any input
2006 Lotus Elise BRG
You've come to the right place. Lots of good information on what could go wrong and how to fix it on this forum. Nothing mechanical is an expensive fix. The expensive fixes are usually accident related.
You don't often see factory supercharged cars for sale. Lucky for you there are few aftermarket superchargers available.
Addict
2007 Lotus Exige S
If you’re used to working on 60’s era muscle cars you should be able to service an Elise just fine, albeit a smaller working area. These cars take a beating on track and hold up well, depending on your use you might be fine with normal services. Also understand these cars are passing 15 years old here in the states, might be some things to address. There are a few good shops with a ton of knowledge if you do not do the work yourself.
Thanks.
I can do al my own work. Outside of engine machining. But have a couple of great shops I use. I am in Indiana so as of now we don’t have any inspection or emission regulation.
2005 Lotus Elise
Ah another Hoosier. Raised in Central Indiana here. What do you plan on using the Elise for? Track days? Joy rides? Garage queen? Overall the car is built quite well, and as LostPawn said, these things take a beating and keep on chugging. Its a Toyota engine so its higher on the reliability scale then others in the same category.
Good luck in your search.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need to know is in here**
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
1 - 7 of 7 Posts
