1 - 20 of 20 Posts
Hy,
we developed a Trunkliftkit for Elise R/SC and would like to ask what do you thinks about it.
With this kit developed by us allows to open the hood almost all by itself, and remains in the final standing position. with gas pressure dampers. What makes us very important in this development kit was that it is reversible and thus no holes or other changes must be made to the vehicle for installation. The installation of the kit is very easy and takes about 15 minutes. The kit consists exclusively of High-quality materials and contributes to longevity, functionality and stability.
For Lotus Elise R / SC 04-11 2ZZ The Trunk lift kit consists of:
-High Quality Gas Spring ball head
-Enginemount end plate stainless steel 2.5 mm (Black Gloss)
-Trunkmount side plate stainless steel 2.5 mm (Black Gloss)
-2X Gas spring fittings ball head (Black Gloss)
-2X Vibration dampers
Total weight: 360 grams
Video-----> http://youtu.be/_7SjOXCwSVk
Cell
Its on ebay ----> Lotus Elise R/SC Trunklift Kit Trunk Lift Kit | eBay
Gamera The Atomic Turtle
sweet. I have a clam hinge - so the lift would need to be disconnected before lifting the clam, but that looks possible.
we have incorporated the theme in the development. the vibrations of the engine are no problem for the kit. Cause if the damper is in the closed state its not fully retracted and so it captures the vibrations of the engine.
Was watching the auction on ebay. The part that worried me was the engine mount, and possible pressure on the engine. Why not make it attach to the chassis?
Got mine and installed it :)
It's opening a little bit less than with the stock fixing (maybe 2-3 cm lower) and was really easy to install !
1 - 20 of 20 Posts
