1 - 5 of 5 Posts
hey guys, I have a quick question, is there any interchangeable starters for the Lotus elsie 2005 2zz engine?
I think my starter is bad and I plan on replacing it.
Also is their any guides on how to replace a starter? Whats the best way to go about it?
thank you in advance
Your thread/post needed moderation to be seen by others. Usually that only occurs when you've just joined and it's your initial post. I've approved it so hopefully you'll get some feedback.
San
Get a factory shop manual to start with
It is kinda up in there, but straightforward to get out
It is toyota standard celica GTS stuff
Usually it is the starter button or something else, starters last over 100k in Toyotas
Yes.
Have you checked the battery or working under an assumption?
What are the symptoms?
^ As stated above, check the battery, or just put in a new one that is fully charged. 90+% of the time it is the battery, not the starter.
1 - 5 of 5 Posts
