1 - 5 of 5 Posts
Hi all,
Im looking to swap a K20a into my Rover powered Elise. Also looking to take advantage of the current exchange rate.
Does anybody have any leads on a complete K20a swap package?
Thanks in advance,
Sam
ps im looking for all the neccessary Honda parts (engine, transmission, water + oil pump, shifter etc), NOT THE LOTUS CONVERSION KIT
Hi all,
Thanks in advance,
Sam
I'm also a Honda enthusiast It's hard to find the best deals, because you also have to consider that the swap package might be shipped with broken sensors, parts, etc. Then it becomes a hassle to try to get the company to replace it.
Working with Hondas since 1999, I can honestly tell you that the best place is probably HMotorsOnline. You can do a search for them.
You get what you pay for, and when you purchase from them, I've always had good experiences.
K20A ( Type R) Motor, Tranny, ECU
Price: $ 5599.00 Plus shipping and handling.
Availability: In Stock
- Motor
- 6-speed LSD Tranny 4.7 Final Drive (Y2M3)
- ECU (PRC) or (PRD)
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold with downpipe
- Fuel Rail
- Injectors
- Coil Pack
- Engine Harness
- Half Shaft
- Shifter Cables and Shifter box (Add $150)
- Comes With All Sensors Needed
Im also thinking of modifying the engine, would you recommend going with USDM or JDM?
Main modifications are to the Head - cams, valves, springs, porting, intake, header, exhaust. (I remember hearing somewhere there was not much difference between the JDM and USDM after modification)
Super Moderator
Hi Sam,
Have you read this thread on SELOC? 40 pages (some to skip!) but worth a read if you are thinking of going down this route.
Cheers,
Steve
1 - 5 of 5 Posts
