1 - 8 of 8 Posts
Dear friends, I am new owner of Lotus Exige. Please help me find a reliable mechanic around NYC area so I can have my car properly maintained. Thank you in advance. :smile2:
Colin Miller (Yes, named after Chapman)
C2 Automotive
500 US 46
Fairfield, NJ 07004
cell: (973) 647-9440‬
Helped me a bit with my Elan and Elise. Sent a few ppl there. All were happy.
In same bldg as Eurotire, but do not use them for alignment or corner weighting. I have a great shop for that.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
For street cars, consider removing one or both oil coolers. Some cover them.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
I’ve used Colin in the past also. The first time I had a good experience. The second time not so much. So I tried out Bill Thomas and he was great. His shop is so freaking clean too.
@glb Gil who do you use for corner balance? Colin actually did mine and I’m pretty happy with it but I’m just curious as to who you recommend.
Wingless Wonder
1988 Esprit Turbo
@glb used PMR (Precision Motorsports Racing) in Califon/Long Valley NJ for corner balancing. (908) 832-6572
Colin Miller (through adjacent Euro-Tire) can perform corner balancing as well.
RS Motorsports in Closter NJ (near the Tappan Zee Bridge) is my favorite...but Ralph is so popular that there are backlogs for routine stuff!
201-750-0700
Wingless Wonder
1988 Esprit Turbo
By the way, we are told that the new Lotus dealer in Summit (LotusNJ) will do corner weighting, and some Elise or Evora modifications as well.
Tony Plesh is the Service Manager 201.669.9537 tell him Atwell sent you.
@Pasha.Lotus
you should join LotusPALS for notices of local events in the NYC area
lotuspals.ning.com
When you get enough posts PM me.
Thanks , carbuff.e
Rb26, I forgot that Eurotire does the weighting and alignment....not Colin.i
I trust Colin a huge amt but NOT Eurotire. Sorry.
1 - 8 of 8 Posts
