1 - 5 of 5 Posts
I was looking at the new European Lotus Exige specifications and was wondering if the optional Lotus Sport parts could be installed on a Federal Elise. From the looks of it the new European Exige is very similar to the Federal Elise with the LSS, hardtop, and exhaust options.
http://sdm3.rm04.net/servlet/MailView?ms=MjM3NjMyS0&r=NDU2ODUwNDAzS0
http://www.kbnet.co.uk/lotus/specs.htm
Lotus Sport can offer the following track aftermarket accessories for the Exige:
Safety
FIA approved 6-point roll cage, driver’s seat and 6-point harness. Fire extinguisher and kill switch assemblies
Performance
Uprated clutch assembly, Limited Slip Differential (LSD), Accusump oil control system
Handling
2-way adjustable suspension dampers, Adjustable front anti-roll bar
I wonder if the Exige engine cover could be retrofitted to fit the Federal Elise? (I'm sure someone will attempt this!) The mounting/hinge hardware is obviously different but does the engine cover roughly fit the same "hole" in the rear bodywork? The Exige's raised center air intake wouldn't mesh with the flat Elise hardtop, but that shouldn't be a huge problem. Just curious.
The rear clam shell is different.
... as is the front clam.....
I did come across a website that sold Exige type read spoliers... not sure it would look right on the back of a 111R/Fed elise...
will try to locate and post
Milan
1 - 5 of 5 Posts
