1 - 7 of 7 Posts
Hi. This is my first forum post.
The problem I have is that I locked my Lotus Exige 08 model this morning at work and at the end of the day I get back the the key fob won't open the central locking doors. It does absolutely nothing. I'm not sure where the problem lies. I can see the alarm tell tale blinking so I don't think its the car battery and I've changed the battery on the key. Any ideas on what the problem may be?
Thanks in advance
If that doesn't do it, it is likely that the CDL (central door lock ) controller has failed. This circuit board is located behind the start button panel, and is an easy fix for the dealer.
The problem is that I am stuck out of the car and its at work. Im in South Africa. There are only 2 dealers and they are about 500km and 1600km away. Is there any way I could at least start it and get it to my house?
Don't know how to re-sync the key fob (read about pressing both buttons on the fob thats separate).
Btw thanks for the speedy replies
Discussion Starter · #7 ·
Ok. Worked it out
First I decided that perhaps the battery isn't working. So I opened the front flap and tried to boost the battery - BAD IDEA. Got a serious burn. Battery seemed good.
Next - Broke into the cabin.
Entered manual disarming procedure with security code.
Finally tried to programme my key - Turns out it won't programme. Managed to programme a replacement key. Guess it was the FOB all along.
1 - 7 of 7 Posts
