1 - 4 of 4 Posts
At what year or serial number did they go from one fuse for each low beam headlight to just one fuse for both. My car is a 2005 and hope it has the two fuse set up for left low beam not operable with new bulb. Hoping it is just the F-17 fuse if I have the two fuse system.
Service Manual sates MY 2004-2011 use the same fuse slots and amperage:
17 10A Dip Beam LH
18 10A Dip Beam RH
20 15A Main Beam LH
21 15A Main Beam RH
Hope this helps...
Less is Better
Your owner's manual won't steer you wrong. I just went through the effort of determining why I had a low beam out. I ended up having to replace the relay box behind the instrument cluster.
1 - 4 of 4 Posts
