Click on reply, then the second item from the bottoom is "Attach file". If it is too big or something, then I can probably host it on my server.pinmagic said:Hmmm.... how do I post it here?????![]()
I have one in my MR2 that does that. Love it.Biomax said:and I would like the door locks to lock once I'm moving.
I thought I saw a separate relay module for the windows on some site that sold the alarm - I suspect that it's needed.pinmagic said:- I want the remote to work the windows. Do I need a separate module, or can I just use the brown/white wire that's labeled "comfort negative output for windows"?
I have no idea, but I absolutely hate systems that do this. If I want the doors locked, I'll push the switch. But that's just me...
- Can I program this system to automatically lock the doors when I start driving, and unlock them when I stop the car?
bumpIn reviewing my lotus documentation included with the car, I can not find any documentation from Cobra than lists my car's alarm pin. I DO have a tag affixed to the spare key ring that says 'delta elettronica spa', and on this tag is a hand written 4 digit number. This same number is also hand written on a long thin separate plastic tag that is also affixed to the key ring. Is this my alarm pin?
thanks
dave
That sure sounds like your PIN. You can tell if it is by trying to put the alarm into programming mode. Just do the following procedure (taken from a fob programming thread) using the PIN you have:In reviewing my lotus documentation included with the car, I can not find any documentation from Cobra than lists my car's alarm pin. I DO have a tag affixed to the spare key ring that says 'delta elettronica spa', and on this tag is a hand written 4 digit number. This same number is also hand written on a long thin separate plastic tag that is also affixed to the key ring. Is this my alarm pin?
thanks
dave
