1 - 3 of 3 Posts
Quick review/how-to...
Got my mitts on MattJK's 3D printed magnetic disconnect charger as it was the coolest looking solution I'd run across - and got the install done today on my Evora 17/400. Importantly, I didn't want to change ANYTHING on my existing wiring harness - wanted the new solution to connect to exactly what was already there.
Removed the existing license plate light fixtures (two screws each) and saw the wiring connected via spade lugs, so crimped four on to the wiring of the provided LED replacement fixtures and they hooked right up.
1274755
Be sure to install the light fixture with the built-in magnet and charging cable on the left/driver side so the wire run will be shorter to where the battery is located.
Evidently the Elise & Exige are a "single panel" in the rear - but after removing a plastic interior cover panel in the trunk (two nuts, two screws and a bolt - piece of cake) saw that the Evora is actually two panel and the wiring for the license plate lights aren't immediately accessible... :(
Drilled a 1/2" diameter hole and ran the charging wire through a grommet (as is done in other places) - easy to drill through as the panel is (effectively) fiberglass
1274756
I have numerous motorcycles, so had a pile of connectors that work with the Lotus provided battery tender - crimped and heat-shrinked a connector to the charging wire now that it's in the trunk...
1274757
Ran the wire under the carpet and plugged in to the existing battery tender connector already in place and trunk looks neat and tidy...
1274758
Put a battery tender connector on the external magnetic connector wiring - crimped and wrapped in heat shrink tubing (paying close attention to get the polarity correct!)
1274759
Here's a close-up with the magnetic "cover" in place...
1274760
And here's a closeup with the charger in place - fits great and you CAN'T reverse the charging connector once it's wired up as the magnet just won't let you.
1274761
Solution works GREAT - is super easy to install with no mods to car (other than that 1/2" hole) and if you don't have Harley battery tender connectors lying about, a cable can be had for $9 from Wal-Mart here: Replacement for Battery Tender 081-0148-10 10' Quick Disconnect Extension Cable - Walmart.com - Walmart.com - just cut it in half when you get it and you'll have a connector both ends without having to chop your existing wiring harness.
Many thanks to MattJK for this ingenious design!!! :)
Kevin
Thanks, Kevin!!
1 - 3 of 3 Posts
