Hi there! Why not register as a user to enjoy all of the benefits of the site? You may register here. When you register, please pick a username that is non-commercial. If you use a name that appears on any search engine commercially, you must pick another name, whether it applies to you or not. Commercial usernames are for supporting vendor use only. If you want to become a supporting vendor and grow your business, please follow this link. Thanks!
Metal grate for bumper opening (rear valance screen).
I was thinking of adding a V8 style metal grate and putting it behind these openings at the bottom of the back bumper. Ideally it would be removable and not alter the bumper itself. Maybe just using double sided adhesive tape used for hanging posters. Anyone have any ideas where to get a sheet of metal thats already got holes cut out like that?
I used an epoxy on the bottom of the mesh to secure it to the rear valance. The stainless frame on the top is L-shaped and bolted to the bottom of the bumper cover.
You should be aware that the V8s with the mesh screens had a full-width muffler/exhaust. It was said that this contributed to the aerodynamic balance of the car at speed.
Folks that removed the muffler were criticized.
So, fitting a valence screen might slow your Esprit down! (Kinda like fitting a rear wing....)
I bought a sheet of grill material from Custom Car Grills dot com, cut & fit each side, and had them powder coated black. The guy was easy to deal with and there is a big selection of patterns to choose from.
Here it is all finished. I had to get steel because I couldn't find anything with the perforation hole size I was looking for. Ended up using Gorilla brand mounting tape to secure it after looking into it, its supposed to hold up to 35lbs. Considering this plate is resting on a lip I think it will hold alright. Really wanted it to be a reversible modification too. Also since I'm in CA I don't think it will rust.
Time will tell!
Looks good. Is that just plain steel no coating? It will rust eventually if so rain or no rain. Maybe hit it with some clear coat?
Related Threads
The Lotus Cars Community
2.7M posts
51.5K members
Since 2002
