I have a 2007 Exige S, (VIN char 4 = V, 13 = 8). However the ECU is from one of the 240 Elise range, but I'm not sure which (VIN char 4 = W, 13 = 3). Same year, 2007. I'm guessing that it's probably a Cup as that uses the same electronic throttle as the Exige S, where the 240R is still a cable throttle.
Looking at the Lotus Service Notes, it seems that the 240's have either high-flow injectors (Cup) or a 5th injector (240R). Neither of which are in the standard Exige S.
Am I OK running this ECU, assuming I can get it past the maniacal CA smog tests with mismatched VINs, or should I really be looking at getting it re-flashed as a genuine Exige S.
Cheers.
Cheers.
