1 - 3 of 3 Posts
Miscellaneous Part Clean Out
These parts came from a stripped down a track car. It is a 2005 Elise red car, Paint code B94. I also have parts that were just sitting on my shelf.
Check the pictures here https://1drv.ms/f/s!ApuaYmE1TxEIglhRQTQT0beoH1aY
If the part is not shown in the pictures, I probably don't have it.
Parts available:
Interior Parts
Aluminum dash support
Shifter plastic cover
Passenger air bag and cover
SRS module
Carpet - behind seat, along side of frame, aluminum channels for carpet.
Top Dash panel
Brake parts
Brake Booster
Parking brake handle and connecting cables
Aluminum handle on parking brake - sold
Body Panels
Engine Access panel
Cowl above rear clam
Fender behind front driver wheel
Passenger door
  • fiber glass shell
  • electric lock actuator
  • window motor and glass guides
  • latch parts
  • grey painted plastic piece behind interior handle
Driver Door
  • door fiberglass shell - sold
  • Door beam and hinge
  • electric window motor
  • window motor
  • latch parts
  • Driver door mirror
Rear window
HVAC system
heater/AC core
blower motor
outdoor air module
AC compressor
Aluminum Refrigerant pipes
Exhaust - Muffler OEM
Electrical
Cobra alarm system pieces
Front Side turn signals on the panel between door and wheel
windshield washer/wiper column mounted operator stalk
turn signal and bright light column mounted operator stalk
Battery cover
Cooling
All oem rubber coolant hoses, radiator and engine bay, heater hoses, etc.
Coolant Tank
3 OEM oil coolers - working no leaks, 1 ea Driver and 1 ea Passenger,
Suspension
OEM Rear toe links 2 sets
OEM Front sway bar
OEM front steering arms L & R
OEM damper and springs (rear b121 d 0003 x "character not readable"
Parts are located in Hobart, IN 46342. I do travel to Oakbrook Terrace, IL. I will ship the parts.
Make me a reasonable offer for the parts. I will likely accept it. If shipping is needed include your zip code or you can send me a shipping label.
Send me an email at [email protected]. You can use the PM also.
I don't have or am not selling
LSS Wheels
wheel arch turn signals or lights
wishbones or control arms
front turn signals
visors
Interior trim pieces except what is noted or pictured.
Wheel liners
1 - 3 of 3 Posts
