1 - 7 of 7 Posts
I drilled a small hole at the center spine so that LED light can be seen when the button is pressed, then I dropped a dab of optically clear epoxy into the hole so that its sealed.
I also bought a Lotus Lapel pin, grinded the pin down a bit, then epoxied it to the key to make it look more "factory"..
I think I used a .030" diameter drill or something like that. I dropped more of the epoxy in today and used masking tape to keep it square (the single drop I had originally wasn't perfectly round)
1 - 7 of 7 Posts
