1 - 5 of 5 Posts
Anyone had a motor mount fail or have them wear out yet?
When I replaced mine it looked like the back one was on the way out. Though I’d need to double check.
If you need a replacement I still have the oem ones
Evora?? Starting to get a knocking sound from engine bay associated with hard on/off gas . Is it garage floor easy or lift preferred work? If change needed, upgrade time.
Yeah Evora
I did it with the engine out so it was easy.
I don’t think it would be much easier on a lift. Still a **** job. It’s really tight in there. I think the back bracket fastens under the clam a bit, for example. You may have to jack under the mount you’re removing.
ive got a heap of photos if you need
That's what I was afraid of. Will ask my service tech if he has any experience with them.
1 - 5 of 5 Posts
