Randy Chase said:
Okay. My plan was to take some MP3 CDs for the ROADTRIP and it would truly suck to find out they can't play. I will read the manual again.
Here are the instructions for the directory structure:
Preparing the MP3 CD
The various combinations of CD burners, CD burning software and CD blanks may lead to problems arising with the ability to play certain CDs. If problems occur with your own burned CDs, you should try another brand of CD blank or choose another blank colour. Best results are achieved with CD blanks that provide 74 minutes of playing time.
The format of the CD must be ISO 9660 Level 1 or Level 2 or Joliet. Other formats cannot be played reliably.
Avoid multi-sessions. If you write more than one session to the CD, only the first session will be detected.
You can create a maximum of 127 directories on a CD. Each of these directories can be accessed using this device.
Each directory can contain up to 254 tracks and subdirectories, which can also be accessed. A maximum of 8 levels of directories are allowed.
Since using some burner software can lead to inconsistencies in the way items are numbered, you should ensure that the root directory D01 either contains only subdirectories containing tracks (Fig. 1) or only tracks (Fig. 2).
Each track can be named using the PC. The directory name can be displayed in the device’s display. Name the directories and tracks using your CD burner software. The software’s operating instructions will provide details on how to do this.
Note:
- When naming directories and tracks you should avoid using special characters.
If you like your files to be in the correct order, you should use burner software that places files in alphanumerical order. If your software does not provide this feature, you can also sort the files manually. To do so, you should place a number (e.g. “001”, “002”, etc.) in front of each file name – the leading zeros must also be included.
MP-3 tracks can contain addition information such as the artist, track and album names (ID3 tags). This device can display ID3 tags if they are version 1.
Only MP3 files with the “.MP3” file extension can be played on this device.
Note:
To ensure uninterrupted playback,
- do not attempt to change the file extension to “.MP3” of any files other than MP3 files and then attempt to play them!
- Do not use “mixed” CDs containing non-MP3 data and MP3 tracks.
- Do not use mix-mode CDs containing audio tracks and MP3 tracks.
