ChromeO said:
any thoughts on how would this work out on the elise ???
NOS Kit
You are probably going to be flamed, so I will try to give you a solid answer before this thread goes downhill.
The NOSzle kit should fit and be able to run a 50HP shot without issue, but the in-tank fuel pump will probably need to be upgraded or augmented.
There are a couple reasons the NOSzle kit is a poor choice for the Lotus Elise:
(1) Once the kit is armed it only has one activation setting, WOT. Even if the system where paired with a progressive controller like the
Nitrous Express Maximizer, the power would still be somewhat off/on in nature and would only be useful while you are driving in a straight line.
(2) The cost of the NOSzle kit is high in comparison to the performance benefits. The drivetrain and engine are not built to take advantage of the huge straight line performance increases possible with NOS.
In my opinion, a low boost turbo or supercharger system (5 to 6 PSI) would be a better alternative and would provide useful performance increases over a wider range of driving situations.
