1 - 18 of 18 Posts
Bought my first Lotus - 2007 Elise from an LT Member and am looking forward to collecting it this weekend and driving it back to Los Angeles from San Francisco (the scenic way down highway 1). From reading a number of posts, it seems many of you can make great recommendations for trusted local businesses to service and/or upgrade a Lotus Elise. Have any of you, great recommendations for the LA area?
Thanks
Andy
That is a CLEAN looking car! Congrats!
My efforts to find an Exige that looks that good continue!
Cheers,
Bryan
Awesome find and welcome to the group! I also have a Chrome Orange Elise and love it. There is nothing not to love about these cars, except maybe the A/C... :smile2: You are in a good area too because most Lotus appear to be on the West Coast. Enjoy!:shift:
Congrats! What a great way to break-in your new relationship!
Be sure to hook up with the LCOSC - Lotus Club of So California. I think they're working on a couple of canyon drives for the next couple of months.
Cheers,
Kiyoshi
Welcome and congrats! That is definitely one clean looking CO(chrome orange)!
I tend to purchase alot of my aftermarket parts either here from the for sale section or from GRP.
Gabe
Clean clean clean! Welcome to the group!
Give you $100 if you can keep a grin off your face as you drive your new baby home! :D
Really nice car!
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Looks amazing! Congrats! Do you know if this car was actually spec'd with that interior? Looks amazing! I think I would like to do the same to mine.
Beautiful car . Hope to find my CO Elise before too long . PCH will be a blast in that , I have done that ride on a bike it's awesome.
Congrats on your purchase!
Look for A1 Automotive owned by Harix on this forum.
He can 100% be trusted with your new baby.
Reactions: blankdan
Discussion Starter #15
Yep, this was the original interior. Color is called biscuit. There is a red car currently for sale in FL with a biscuit and red interior vs my black and biscuit version.
Welcome! That seat color looks like magnolia. Biscuit is a darker tan color. The underside is very clean and very little evidence of scrapes. The PO must have been very attentive to this car.
07 Exige S
Beautiful Unit man!
I am jealous as all get out looking at the leading edge under your clam... Let's just say I have a little bit of work to get my clam looking acceptable...
Honestly, it would be rather expensive for me to try to get it to that level of perfect, but in a way. Out of sight out of mind...
I have driven my car from San Jose down to San Diego during the "superbloom" a few years ago just before heading east again. It looked like a honest to goodness painting with all the hills painted yellow and green.
Discussion Starter #18
Beautiful Unit man!
thanks Motard. Drive back was awesome yesterday
1 - 18 of 18 Posts
