I have finally completed a few of my winter mod projects. I have all of my mesh grilles finished and installed, and I put the original rear panel back on. I removed it to put Phil's clam hinge on but I just didn't like the open look. It took a little bit of modification to the rear panel and 3 additional thumbscrews, but I got it to work. You can see in the one picture the gap that is between the rear panel and the clam once all the thumb screws are removed
I was able to do the front grilles without removing the clam. The screws that are in the center grille area are just to fill up the holes that the original plastic grille mounted in. I did drill a new hole on each oil cooler grille and installed a matching screw that actually holds the grille in place. I figured that I would do it this way because I used the same screws on the grilles for the rear of the car. Please let me know what you guys think of how it looks.
The side scoops were a bit tricky and time consuming. I needed them be sturdy enough just being mounted to the lower portion of the car, because of the clam hinge. I am really happy with the the way they turned out. And they are mounted with just 3 screws each and they are very secure. I just have a little bit more tweaking to the side scoops just to make them look more finished when the clam is tilted.
I also finished installing my HID's this afternoon. Still on the list for winter mods include finishing the painting of the engine covers and some interior parts, installing my multivex mirrors, and polishing up the E-brake handle and shifter lever and ball.
Here are some pics, the car is rather dirty and dusty and please excuse the clutter in the garage.
