1 - 18 of 18 Posts
I am now a proud owner of a new to me 2011 Elise R
A couple of pics taken fueling up on the way home
Your Elise is beautiful!! Congrats.
Very nice car. Congrats.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
For street cars, consider removing one or both oil coolers. Some cover them.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Very nice.
There's only a handful of us S3 owners here in the US. Small club.
My Elise is Laser Blue which I absolutely love. But your pix have me yearning for the days when I had a Europa in Arrest Me Red. Gosh your pix look nice.
Congrats!
Discussion Starter #15
I think you got the good one.... It is definitely in good shape. I am wondering if the fourth got totaled? Quite common with these cars and it would make ours even more rare! Congrats again on the purchase. These are quite rare, however, there were a few more between the SC's and the Final Editions.
1 - 18 of 18 Posts
