....and I'll bet yours is, too! :huh:
Today, I noticed that the liner is separating from the plastic side-bar, toward the front end of the driver's side. The liner is mounted in a gap in the side-bar, and the front third has simply come out. Not sure how it's held in there -- I see traces of glue, but there must be more to it than that.
So then I looked at the passenger side, and while it's still fully in the gap, a very slight tug at the front end was enough to start pulling it out.
So my guess is, a lot of you will start seeing the same problem.
Here are the pics -- one shows the liner separated from the side-bar. The other clearly shows the gap in the side bar where the liner is supposed to be mounted.
Bummer.
Bummer.
