my tires at about 2900 miles *updated* tires at 3100 miles
fronts
fronts
rotfl what he said! :shift:Aedo said::up: :up: Good work!
If you mean mileage, yes. Be sure to check your pressures hot - they gain pressure when the tires heat up.bluejae said:but does it look like normal wear even if it may have been overinflated?
whatever was on the door sill... i think that's where i saw it... but a little less than that... but i'll set it to 26 tomorrow before i go out...nugg_dawg said:I generally set mine at 24 psi front and 26psi in the rear cold.
BTW, what were you running when you said they were over inflated?
John
winter air? summer air??? :huh:Bleu Omdurman said:Don't forget to change out your winter air for summer air.
pressures tend to shift as much as 1 psi a month in GA transition from feb to Jun.
