It's happened a few times when I hit bumps or something, but this time it came out for no apparent reason on the highway. I lost the rubber seal and had to tape it back in.
Yeah that's what I was planning on doing, but unfortunately I lost the rubber seal that goes around it too. Gonna have to order a new one maybe from the dealer.Get a small bungee cord. Drill a small hole in the broken clip to connect bungee. Find a place/pipe on the car for the other side. Problem done.
Replacing the unit is the correct fix, but the problem will just happen again.
Same here...little RTV silicone solved the issue, never happened again.Yes about search.
I hid some silicone seal under the gasket. Has worked for yrs.
:up: That's what I did when mine finally popped out earlier this year.Just used the bungie cord fix for broken turn signal tab. Free, simple, and it works! Had to wrap my bungie around the support twice to get it the right size.
