1 - 4 of 4 Posts
This is a view looking into the front driver's side wheel well. In my hand is a mystery wire that's cut off and is quite heavy gauge where it comes out of the vehicle part line and then becomes a very light gauge before terminating in a cut and stripped end. There's a tag on it that reads, "signal element." All of my lights, signals, etc, up front work fine. Does anyone know what this wire does?
I believe that’s the radio antenna. Mine was located running down the similar area. Just tuck it back up towards the front.
Gabe
Gabe
Thank you! That's about the best answer I could have hoped for. . .
'07 Exige S
if you remove the plastic inner fender liner the antenna usually is glued/taped up against the upper clam shell.
the antenna wire end is not bare like your photo shows. it has a molded plastic tip.
the alarm siren is located up front on the driverside. might be part of that.
Henry
1 - 4 of 4 Posts
