Hi, did spend significant time using the search function but still need help on this. 07 Exige S, track pack. Other than 6 pt harness, larini, pagids and soon to be installed engine mounts and RTDbrace it is stock. It is lowered and aligned to the OE track spec.
BTW was not 100% sure whether the proper approach was the RTDbrace vs. the Deltabrace because of the track pack?
Back on topic: need a second set of wheels and thinking of either R888 or Hoosier R6 for them. Narrowed it down to S111's stellaCorse (16x7 & 17x8 offsets 27/35) or the TR F1s (16x6.5 & 17x7.5 offsets 32/37).
On the stellaCorse Hoosiers can go as big as 225/45 16 and 245/40 17. Anyone running this setup, any issues with rubbing, ABS or anything else? Seems like a very large difference to stock.
On the TR's Hoosiers go 205/45 16 and 225/45 17, and the R888s keep the OE front and give a bit more on the rear at 235/45.
Leaning towards the TR's since it seems preferable to have the identical OE spec and maybe keep one set with R888 and the other with Hoosiers so I have a choice on track support requirements.
Unless the larger stellaCorsas offer a great usable benefit of more rubber with no issues...
And by all means open to other tested setups.
Sorry for the basic questions and thanks in advance!
