1 - 2 of 2 Posts
Just removed two big amps with custom cabinet from the trunk and noticed that the flooring had been removed. Any idea where I could purchase the flooring for the trunk. I am guessing that the flooring from any of the V8's would fit?
Try Sports Car World in Texas. I do not know if they are up and running yet. If you can't get them directly check with Jeff at JAE. He seems to know what is going on with them and maybe he can get the floor for you. You also probably need the piece of carpet. The bolts and washers you can get locally. How is the header bottle being held up? I am guessing they cut the floor and the piece behind the motor is still there. If you can't find a floor you can always make up the piece you need out of fiberglass.
David Teitelbaum
1 - 2 of 2 Posts
