1 - 10 of 10 Posts
Battery went dead in my new to me 07 Exige S. I did a few searches, what battery should i get?
This will be a street car not a track car.
Thank you
G
You have a lot of cars so you probably have a few battery tenders on hand. This is what we went with:
PC680 Bracket | Really Light Stuff
bolts right in, I leave the car on a tender if undriven for more than a few days, just like I did with the OEM battery.
-chris
Ballistic Performance Evo2 16 cell Li-Ion battery. I've had it 5 months now and it's never let me down. Weighs 3 lbs. Stock battery weighs 34 lbs. I used a metal strap to tie it down using the stock threaded holes in the trunk.
Works with your typical battery tender as well.
I notice absolutely no difference since switching. If anything the car feels more nimble.
I found mine for $225 on Amazon. I don't know if that's the current price or not.
The braille 2015 works great if you don't mind using a tender. Mine came with my car, so I have no idea how old it actually is, bit it's been fine for me for the last 3 years. It's good for about 2 weeks without the tender. I've accidentally drained it 2 or 3 different times, and it continues to come back to life.
Beware the hold down brackets though. The s111 ones will not restrain the battery vertically. A big bump will peel these brackets right open. I have the crack in my clam to prove it.
· Premium Member
I've got this one too in my daily driven Elise - never used a tender and have left it for a week or more and still started perfectly :)
I've had it for maybe a year??...
That is the lightest battery for the money I've seen. I just replaced the stock battery on my '07 (26lbs) with the PC680. I didn't know about this 3lb option. The nice thing about the PC680 is there are a couple ready made bracket options to just bolt in. I purchased from an Odyssey dealer along with an Odyssey approved battery maintainer.
· Premium Member
Michael,
These are the only specs I can find on the above mentioned Ballistic.
What do they tell you?
What questions should I ask?
Thx.
Dimensions (Metric): 122mm (L) x 86mm (W) x 148mm (H)
Dimensions (Standard): 4.8" (L) x 3.4" (W) x 5.8" (H)
Negative Terminal Location: Left
Weight: 1621 grams (3.51 lbs.)
Voltage (Charged): 13.6V
Amperage: 9.2Amp/Hour
Lead Acid Equivalent Amperage: 28 Pb-eq/Ah
Burst Cranking Amps: 500amps
Operating Environment: -18°C (0°F) to 60°C (140°F)
Typical Applications: Touring bikes, Harleys, 1500cc and up multi-cylinder motorcycles, jet skis, large side-by-sides and ATVs.
1 - 10 of 10 Posts
