1 - 3 of 3 Posts
Elise newb
My 2006 Elise passenger side door has a problem. The steel bracket that holds the upper part of the rear window track has debonded from the fiberglass door. I have tried two repairs using JB weld and both have failed within weeks of the initial repair.
I think I am going to clamp it up, and drill through from the inside of the door and use a shallow panhead bolt and nut to secure it. I used some gum to see how much clearance I get and I can make it by a hair.
Before I go down this rather extreme path I was wondering if anyone else had seen this problem and had a better fix.
I had this problem in the driver's-side door and repaired it successfully using JB Weld. Here is my post on the repair.
Elise newb
I had not seen your repair write up but it is essentially what I did. I will try it one more time and try to get a better surface on the bracket.
Sent from AutoGuide.com App
1 - 3 of 3 Posts
