Turtle Wax Bug and Tar Remover brings back old memories...but there are better things out there. My favorite? Poorboy's BUG SQUASH. But before I go into that...
WHOOOAAAAAAAA
If there are excessive buggies on your vehicle you should NOT go STRAIGHT to the clay bar or wax (I am not sure if this was meant). Excessive buggies require lots of lubrication to prevent the harden bugs from scratching the paint.
BEFORE YOU GRAB THE CLAYBAR
If you use a clay bar on a bug, some of its hard fragments will get stuck into the claybar, and then once you move the clay bar around the surface for additional passes those fragments stuck in the clay bar will scratch your paint.
WAXING
Waxing a surface to remove bugs sounds terrible, sorry. Wax is not designed to do this, it's designed to protect the paint. Just like the clay bar situation, your wax applicator will get contaminated with hardened bug guts and once that contaminated applicator gets on the paint...SCRATCHES!!!!
The CP Car Detailing Recommendation:
1. I know it's a pain but for the ultimate in prevention you should really wash the area, and do it gently with some lubricated car wash soap to get most of the bug residue off the surface. DO NO SCRUB
2. Once rinsed off, determine if you are satisfied. If not, spray some Poorboy's BUG SQUASH (I like a dilution of 1:3 with water), let dwell for a about 3 mins, then re-agitate gently and RINSE.
3. If NOT satisfied at this point, go ahead and try the clay bar with your car wash soap as lubrication.
4. Once rinsed, go ahead and wax the area you just worked on.
5. Enjoy your bug-free finish :coolnana:
NOTE: Since I am not sure if the posters who mentioned waxing or clay barring meant to jump straight to those methods (a context issue), I went ahead and explained my entire process. No mean to offend, just worried that some may get the wrong idea and ruin their finish.
For the most extreme bugs, I would soak a towel in water and let it sit overnight on the areas that are filled with bugs. In the morning the bugs will be softened and easier to remove.
The best prevention to make bugs easier to remove, and hence, more gentle to your paint is having a fresh coat of wax on your paint at all times. Also, try to remove bugs from the front end as soon as you can, to prevent hardening and future scratching upon removal.
