I feel like a real idiot with this one, but I figure I had better ask how to remove the engine harness connectors from my ECU before I break something. The car in question is an '05 Elise with the T4 ECU. The problem I am having is that the sliding clips will only slide about 1/4" which is not enough to allow the harness connectors to come free of the ECU and trying to do this by touch because I can't pull the harness up enough to see what is going on is aggravating the process. Is there a lock on the clips that I need to push while trying to slide them or are these clips just that hard to move? Seeing as there is no way to work on these connectors from above the engine bay except by touch, does it help to try to access them through the wheel well after the liner is removed or from underneath with the undertray removed in order to get a visual on I am trying to do? What am I missing here? :shrug:
TIA for any assistance you can give me.
