Well, here is how it went down. On the track Friday 6/13 hi rev then boom coolant on windscreen. Hand out the window, drove around to exit track. Temp never got hot until I exited the track, then when I was really slow it started to rise. Cut off engine and coasted to parking.
Coolant pouring out below the radiator primarily on the left side (driver's). Trailered it home now it's up on jacks.
Pulled the appropriate panels could see no leaks but couldn't see where the lower radiator hose connects with the radiator. It's way up under the clam. Filled it up, started it and it again was leaking on the left. Turned off the car at 210d, the fans never came on and the lower hose never got hot.
That's where I am. Need all you guys experience. Pls.
I think key is coolant on windscreen.
