Not too familiar with ECU scan reading... This is for 2008 Exige S 240 with 1800 or so miles. Is there anything on here that I should be worrying about?? Experts please chime in on this as I'm about to close the deal. TIA
Group--- ----------- category---- Data--- Unit
Coolant Temp-- 115-120 Deg C-- 0:0:0-- Time (H:M:S)
Coolant Temp-- >120 Deg C- 0:0:0-- Time (H:M:S)
Max Engine Speeds-- Max RPM 1-- 8823-- RPM
Max Engine Speeds-- Max RPM 2-- 8771-- RPM
Max Engine Speeds-- Max RPM 3-- 8731-- RPM
Max Engine Speeds-- Max RPM 4-- 8710-- RPM
Max Engine Speeds-- Max RPM 5-- 8705-- RPM
Max Engine Speeds-- Coolant Temp 1-- 88.54-- Deg C
Max Engine Speeds-- Coolant Temp 2-- 88.54-- Deg C
Max Engine Speeds-- Coolant Temp 3-- 88.54-- Deg C
Max Engine Speeds-- Coolant Temp 4-- 86.05-- Deg C
Max Engine Speeds-- Coolant Temp 5-- 88.54-- Deg C
Max Engine Speeds-- Max RPM Engine hrs 1-- 16:41:26-- Time (H:M:S)
Max Engine Speeds-- Max RPM Engine hrs 2-- 16:44:16-- Time
Max Engine Speeds-- Max RPM Engine hrs 3-- 16:37:51-- Time
Max Engine Speeds-- Max RPM Engine hrs 4-- 16:23:36-- Time
Max Engine Speeds-- Max RPM Engine hrs 5-- 16:45:41-- Time
Max Engine Speeds-- Max KMH 1-- 172-- KMH
Max Engine Speeds-- Max KMH 2-- 166-- KMH
Max Engine Speeds-- Max KMH 3-- 165-- KMH
Max Engine Speeds-- Max KMH 4-- 160-- KMH
Max Engine Speeds-- Max KMH 5-- 159-- KMH
Max Engine Speeds-- Fastest 0-100 KMH-- 25.5-- Time (sec)
Max Engine Speeds-- Fastest 0-160 KMH-- 25.5-- Time
Max Engine Speeds-- Last 0-100 KMH-- No Data Avail-- Time
Max Engine Speeds-- Last 0-160 KMH-- No Data Avail-- Time
Throttle Position-- 0-1.5%-- 17:7:54-- Time (H:M:S)
Throttle Position-- 1.5-15%-- 56:57:39-- Time
Throttle Position-- 15-25%-- 5:1:17-- Time
Throttle Position-- 25-35%-- 0:55:49-- Time
Throttle Position-- 35-50%-- 0:37:20-- Time
Throttle Position-- 50-65%-- 0:19:41-- Time
Throttle Position-- 65-80%-- 1:12:38-- Time
Throttle Position-- 80-100%-- 0:0:0-- Time
Engine Speed-- 500-1500 RPM-- 41:51:58-- Time
Engine Speed-- 1500-2500 RPM-- 11:52:49-- Time
Engine Speed-- 2500-3500 RPM-- 15:28;47-- Time
Engine Speed-- 3500-4500 RPM-- 8:35:36-- Time
Engine Speed-- 4500-5500 RPM-- 2:36:58-- Time
Engine Speed-- 5500-6500 RPM-- 1:8:17-- Time
Engine Speed-- 6500-7000 RPM-- 0:16:44-- Time
Engine Speed-- 7000-7500 RPM-- 0:8:43-- Time
Wheel Speed-- 0-30 KMH-- 47:59:23-- Time
Wheel Speed-- 30-60 KMH-- 13:10:45-- Time
Wheel Speed-- 60-90 KMH-- 11:8:4-- Time
Wheel Speed-- 90-120 KMH-- 8:39:22-- Time
Wheel Speed-- 120-150 KMH-- 1:11:38-- Time
Wheel Speed-- 150-180 KMH-- 0:3:6-- Time
Wheel Speed-- 180-210 KMH-- 0:0:0-- Time
Wheel Speed-- 210-240 KMH-- 0:0:0-- Time
Coolant Temp-- 105-110 Deg C-- 0:0:0-- Time
Coolant Temp-- 110-115 Deg C-- 0:0:0-- Time
Max Vehicle Speeds-- Total Engine Running-- 82:12:21-- Time(H:M:S)
Max Vehicle Speeds-- Number of Standing Starts-- No Data Available
