1 - 7 of 7 Posts
Beautiful specimen.Welcome to the family!
Drone Racing Pilot
Awesome way to start 2020! Welcome to the Lotus Fam!
Very nice car!
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need to know is in here**
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
2005 111R (Elise)
Very nice car!
Stock: “Excuse me”
5. Transmission:
And, use:
How to Bleed Brakes
How to Search:
I realized I never thanked you for this post reply!!! Thanks!
1 - 7 of 7 Posts
