1 - 10 of 10 Posts
Hi everyone. I'm new here. I was most recently driving an AP1 S2000.
Recently changed to an 07 Elise with a soft top.
It's a fun car to drive. It has a few little issues. Air con not functioning, but I think I've solved that, just waiting on a part.
Oh, by the way, is there a factory service manual kicking around on this forum? A cursory search reveals only wiring diagrams, which are nice...
Cheers.
Congratulations and welcome to the community. The service manual that I found online some years ago is too big for the posting limitations of the forum, I'll include a link. I'll include a link to the owners manual also if you don't have one of those. If the wiring diagrams you mentioned were the colorized version, thank you, I put a lot of time into making those.
I'm sure there are others from the community that will post some good-to-know things about the Elise and how to find things on the site so keep watching the thread. We'd all like to see pictures of your new car and there might be some people that know the some of its history if you don't already know.
http://www.robmaroc.com/documents/2004-2012 Elise Exige Service Manual.pdf
http://www.robmaroc.com/documents/Elise Owners Manual.pdf
Reactions: Motard
These cars are simply great. Congrats!
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Thanks for the information and quick replies!
To answer Jetblast, yes, the colorized diagrams are the ones to which I am referring. Good work! I posted a (now redundant) thread in the hvac section before I found wiring info. Solved before the thread was even moderator approved. Good stuff. Thanks for the manual link too.
I'm traveling right now. I'll throw up some pictures when I get home.
GLB, thanks for the intro. Lots of stuff to go through. Have to glance through the manual and make sure the factory PIN is available. All original manuals are present, but the code card is missing.
I have 2 factory keys and 2 factory fobs, but only 1 fob functions. Have to look into that. Living without redundancy is ... Undesirable.
Welcome and congrats! Another S2K owner has come to the lightside. I also had an AP1 before coming to the Elise. Enjoy and drive safe!
Hi everyone,
Steve Tillett here. I have just bought an Elise S1. I have always wanted a Lotus after one of my first memories of seeing Jim Clark slide around Brands Hatch. Finally I‘ve got one and if you haven’t guessed, I make the Tillett Seats so I’m happy to help anyone with advice.
Welcome! My 12 years with an '05 Elise were delightful. I'm praying that they won't have destroyed my chances of enjoying any other street&track car I'll ever own.
Discussion Starter · #10 ·
So... I've posted (or tried to post) 3 threads so far.
1 relay question in the AC forum, 1 about an alarm hack shortcut in the Elise forum, and 1 similar in the electrical->alarm/immmobilizer sub forum.
None of the threads have posted. They all show a text about moderator approval immediately after posting, but then they never go up. Am I missing something?
I was about to throw up a thread about TSB 2006-33 about the AC hose because I have some new information to share after repairing the chassis low side line, but if I can't post threads then...?
I answered the ac question myself from Jetblast's diagrams, so thanks again.
The alarm thread was about how to hack the alarm in 10 minutes rather than 2+ hours
The AC thread is about why the low line fails where it does, how to prevent it, and how to repair it on-car by welding
1 - 10 of 10 Posts
