1 - 16 of 16 Posts
Hello everyone! Somehow I thought I had already posted an intro but apparently I did not. After years and years of fantasizing over An Elise, I finally got myself one last Friday. 2005 Silver Touring , 16k miles with red interior and just a few mods including sports suspension and a Larini SE exhaust. Car is awesome, used but not abused so I can enjoy it without suffering it... I already interacted with a few of you to buy some items. This forum is amazing and makes ownership so much more fun. Looking forward to the day when I can meet some of you in person and continue learning about these cars.
BTW AvidReader is an ironic username based on the fact that for the longest time I was on the sidelines reading your posts and not jumping in! Maybe I should change it now :)
Administrator
Welcome to LT! Congrats on your new car! I was a lurker for six months before joining and jumping in and another 4-5 months with a WTB before finding the right car.
Congratulations!!! Here's to many many years of Lotus enjoyment.
Post a few more photos please... and be sure to check out the Golden Gate Lotus Club (GGLC). Long standing and normally super active (however, activities are limited under the current pandemic) club based in NorCal with sister clubs in LA, San Diego and Sacramento.
Cheers,
Kiyoshi
HI!!
Welcome to Lotus ownership! :)
I am very fortunate to have owned mine since new 2006 and loved every minute. Just driving it gives me joy and its therapeutic!
Yes, even when its down with issues I have learned a lot and really appreciate the car, I try to do my own maintenance unless I don't have the tools or confidence.
The know how comes from this great community of owners and enthusiasts.
You are in for lots of fun.
These are great cars.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
Thanks to everyone. This list is awesome. I have three or four of these already covered. It looks like I still have lots of tinkering fun to do.
2005 Lotus Elise; 2007 Lotus Exige S; 2012 Porsche 991S
AWESOME! Welcome and hope to see you around the bay area!
@chiarov Are there Bay Area group outings organized in this forum nor is it the Golden Gate club?
Well, given covid-19 there haven't been a lot of outings to be honest. @forkmeupscotty used to arrange some semi-regular lunches but that is all on hold.
There are a number of Bay Area Cars and Coffee events that you can find on facebook when things return to normal.
Otherwise, yes, GGLC is great at organizing trackdays, autox, drives, garage shop talks, socials/BBQs.
There's some discussion afoot to arrange some drives of 2+ hour duration with social distancing soon. I did a drive with my neighbors through the back roads of Sonoma, Napa and Solano counties a few weeks ago. Traffic was very light until we got to Lake Beryessa.
Currently on the GGLC calendar are:
Aug 10 - Track Day at Laguna Seca (sold out)
Sep 12 - Autocross at Cow Palace (limited to 50 drivers, expect registration to open mid-Aug. Will likely sell-out quickly)
And, as Dan suggested we are looking into a series of 2-3 hour drives (volunteer tour/drive leaders?)
All done with health safety in mind.
Cheers,
Kiyoshi
1 - 16 of 16 Posts
