1 - 5 of 5 Posts
Been looking for a while and finally got an Elise. Couldn't pass up a 2007 chrome orange with 12k miles, so I flew to Jacksonville, FL and drove it back 950 miles. What better way to get to know the car than a long road trip :) Car is going in next week for new PPF, stripes, paint correction, and ceramic coating. Then hopefully some warmer weather and more running with the bulls and my roommate's viper!
Wingless Wonder
WELCOME!
Can you compare the driving experience compared to that blue car in the last picture?
I haven’t driven it yet, maybe some day he’ll let me haha. But at 6’0” I have to slouch to be able to see out of the viper. I believe the driver seat has height adjustment though so maybe it’s better. The power is insane, but definitely can’t be as confident about traction as the lotus. Interior noise level is similar. Just my first impressions, I don’t have much seat time yet.
Great for you.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need to know is in here**
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
1 - 5 of 5 Posts
