1 - 20 of 20 Posts
Hi from central PA. I picked up this 2009 Elise almost 2 weeks ago and I have already logged over 600 joyful, spirited miles on it. It has 35K miles, recent oil & brake fluid service, oil line recall done, and aside from some scuffs on the driver's door sill, missing toolkit, a few broken snaps in the trunk liner, it's very clean overall. I do have one question so far: does anyone know what this part is? I found it on the floor, by the rear left corner of the driver's seat.
Wingless Wonder
1988 Esprit Turbo
Welcome to the Funny Farm! :grin2:
You should also sign up on LotusPALS (the local Lotus club, Philadelphia Area Lotus Society)
http://lotuspals.ning.com/:bow:
:UK:
Good for you.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Discussion Starter · #7 ·
Good for you.
Stock: “Excuse me”
5. Transmission:
And, use:
https://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
https://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
https://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
https://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Thanks for the info and to-do list!
Less is Better
Thanks for the info. I should probably look for an at-large bolt under the seat too!
It's part number 4.
The only thing I can think of is that it holds the carpet on the rear bulkhead down or it's just an odd shaped washer so that it doesn't get lost when installing/removing the seats.
Discussion Starter · #10 ·
I see that one picture is in front of a collision repair shop. I hope that's not related to the car ;)
LOL, no. It has a clean title and was owned by a car dealer on this forum who also owns an Esprit.
Thanks for the parts diagram!
Wingless Wonder
1988 Esprit Turbo
Sounds as if it came from @carsalesman (as did our Esprit). :clap:
Reactions: Tengai650
That's a great looking car with the hardtop!
Congrats!
2006 Lotus Elise
Congrats and welcome! Let me ask you a question as a new owner, this is something I'm always curious about; you were looking for a fun-to-drive sports car, why the Elise? What attracted you?
I'm just curious how people arrive at the decision, given the relative obscurity of the brand, the plethora of used Caymans and cars like the BRZ and MX5 being widely available...
What other (if any) cars did you consider?
I almost bought an Alfa 4C (reliability concerns) and then I considered a Mk1 NSX (still love those) but ended up buying an Elise.
Again, welcome! This is a GREAT community and incredible resource for owners of these special cars.
I'm glad you ask this because it is something I always ponder as well. Initially for me, the first thing about the Elise I fell in love with was the unique styling/size. There is some sort of presence these cars emit when looking at the Lotus in the flesh (not in the same way as a wide Lambo etc...it's different). I remember visiting the dealers back in 2008 just drooling... I don't get the same feeling when I'm looking at a bloated Ferrari (Those are just TOO BIG nowadays). Ultimately, for me it came down to (1) looks, (2) the driving experience, (3) realizing I could possibly buy damn thing!
2005 Elise LSS Saffron Yellow
For me, it was an 'I always wanted one of those (starting with the announcement of the S1 Elise in the '90s) and now I can finally actually afford/sort-of justify one. Even better, the S2 FED car has a Toyota driveline instead of something obsolete, obscure, and English. I was sold on the theory, and that was before I looked at the car in person.
The first time I saw my car it was parked (indoors) in a row with a DB7 DHC, a Gallardo, and a GT3 Carrera. The Elise was a spicy little gem among all the ridiculous excess (in one way or another) of the other cars. It was just as purposeful - just as essentially Lotus - as I'd hoped. The only thing the other cars had that I actually liked better was the buttery-soft leather on the Lambo, but it didn't justify the rest of the 'owning a Lambo' experience.
I've had mine for a little over a year now, spent several hours under and on it (improving, not fixing) and it still gets a smile from me every morning when I walk out to hop in for the morning commute.
Discussion Starter · #18 ·
Thanks! I always drove something interesting and quirky (vintage SAABs, Land Rovers, etc. over the past 30 years), and I haven't paid a car mechanic since I was 19. I was previously driving a minty 1981 RX7 for the past 8 years. It handled beautifully, and was very light (2,200lbs). However, although it loved to be revved, I frequently found myself frequently reaching for a little more power as time went on. It had a huge sunroof (almost the entire roof), but I also decided that it would be nice to have a convertible. So I started to look about a year ago.
I first considered a Porsche Boxster, but after reading about the intermediate shaft bearing issue, lack of a recall and pricey aftermarket upgrade, I decided to pass. No wonder these cars have almost no resale value. Also, Porsches of all shapes & sizes are extremely common. They're rather ordinary, and kinda boring.
Next was the Toyota MR2 Spyder. I viewed that as sort of a "poor man's Boxster." The funny thing is, it's also the poor man's Elise. It's like an anemic missing link between the two, but still somewhat light and more powerful than a 1st gen RX7. However, it's a bit too cute, and after I saw several high school kids driving them, I decided that I couldn't be seen in such a femmy little toy.
One brief tangent I went on during my search was to go with something vintage. I thought about Triumph Spitfires, pre-'85 Alfa Spiders, and the Lotus Elan.
However, most of the affordable vintage cars are gutless maintenance hogs that don't handle any better than the RX7.
Next stop was the current Mazda MX5. It's a great design, but since it's a current model it's pricey. I figured if I'm gonna shell out that kind of money, let's go with something really interesting, and let's take a take a much larger jump in performance over the RX7. I wanted something more extreme, not just "fun."
So, I revisited the Elise. After doing much homework, I decided that the Elise was the best car for me, factoring in all things such as, drivetrain reliability, styling, handling, price, uniqueness, kerb weight, insurance costs and fuel economy. The only real downside is the parts stream availability and price. I'm so used to having accumulated several parts cars, but a wrecked Elise is about 15-30 times more costly.
2006 Lotus Elise
Porsches of all shapes & sizes are extremely common. They're rather ordinary, and kinda boring....
...a bit too cute, and after I saw several high school kids driving them, I decided that I couldn't be seen in such a femmy little toy...
...I figured if I'm gonna shell out that kind of money, let's go with something really interesting...
...the Elise was the best car for me, factoring in all things such as, drivetrain reliability, styling, handling, price, uniqueness, kerb weight, insurance costs and fuel economy.
Amen to the above and thank you for the thorough answer. I do sometimes feel the gravitational pull towards some other fun car that I've long admired, an NSX, R8, F430, Cayman, 911, 4C etc...but none of those things deliver what the Lotus delivers for the money. I want to drive and enjoy the car as much as possible and as economically as possible, and that's where everything else in this performance category starts to fall apart. I may finally start doing some selective upgrades now after nearly four years of ownership and spending a bit more time on-track. I think that will reinvigorate my excitement for the Elise.
Enjoy yours!
1 - 20 of 20 Posts
