1 - 4 of 4 Posts
Hi All - after lurking for a bit and researching not only online listings but also through this forum, decided to head out and pull the trigger on an ‘05 Laser Blue Elise from WireWheel. (Want to advise anyone on the fence or looking to buy that dealing with Hayes at WW is super easy and a very straight shooter. Vehicle ran like a top and drove it home from Florida to Texas over the weekend.)
Im a Houston local so hope to see some of y’all around. This afternoon will be attaching a front splitter and while working down there I’ve already got on hand a Nautilus horn to swap out.
Looking forward to future discussions and threads.
Good for you.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need to know is in here**
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
Glad you got to break it in right with the long drive home! Hows your back feeling :)
Welcome to the lotus world, its addictive!
We are all different, but I find the car really comfortable, even after 18 straight hours.
Don't forget the air bladder in each seat, with a squeeze bulb.
1 - 4 of 4 Posts
