1 - 20 of 25 Posts
Hey guys,
I have been working with Chuck Risen to come up with an all-in-one bracket + scoop + mesh design, and it's finally here! I went up to Chicago last night and he helped me install and get everything "perfect", as this was his first set of scoops and he didn't want to have any snags / scratches to the paint (body-matched to Chrome Orange).
I know a few people have been asking, and now there's FINALLY a cost effective option that people can use, with a trusted paint source. The whole set will cost $450 shipped, including newly designed - SUPER lightweight - fiberglass brackets + scoop (molded from an OEM Exige scoop, painted to your preference) + mesh, in a clean package. It took less than 1 hour to install everything, and that's with Chuck being picky to make sure the final product looked great! :bow: All hardware was provided by Chuck; mesh + hardware sourced from Lotus OEM.
There are 4 fiberglass "brackets" that will hold the scoop in place. They re-use the existing mounting positions and hardware from the "fins" and do not require ANY drilling to the body. They are molded from black resin, so the ones you get will likely be a little "cleaner" than mine, since we scratched them up slightly through the test-fitting process.
Assembly process:
1. Remove wheel / wheel arch liner
2. Remove 2 bolts from back of the "fin"
3. Install 3 of the 4 brackets, for the top 2 visible scoop screws, hand screw those in place to "hold" the scoop
4. Install the bottom bracket, hand screw the bottom scoop screw onto the scoop
5. Adjust as necessary - VOILA!
I am *NOT* making any money off of this; I was just tired of other designs that were >$800, not including paint / mesh and found someone (Chuck) to assist me. I would say the whole assembly, including scoops, may have totaled 7-8 lbs. It's unbelievably lightweight; I'll see if I can come up with an official weigh-in.
Below are some photos; ENJOY! Feel free to contact Chuck ("chuck_risen" or [email protected]) if you are interested, as the molds for all the pieces are already in place.
Discussion Starter · #2 · (Edited)
There are 4 fiberglass "brackets" that will hold the scoop in place. They re-use the existing mounting positions from the "fins" and do not require ANY drilling to the body.
Here are some photos of the assembly process:
:up: Nice!
Very nice! Would love to see a wider than stock Exige scoop too.
Discussion Starter · #7 · (Edited)
That was one of the issues that we ran into: do we mount a larger scoop and *possibly* have it not fit the existing weatherstripping, or do we start with a stock Exige scoop, mold it off, and make the product and maybe branch out from there? Clearly, the latter won, but it still looks great and much more aggressive / less maintenance than the fins.
Not sure if this is as exciting to everyone else as it is to me, but it's great to have a single-source for all of this (bracket, scoop, hardware, mesh, paint), plus have it in a reasonable price range. Another supplier quoted me $500 shipped for just the bracket & scoops, no paint or mesh.
BTW: just holding the scoop in my hand, it's approximately 60% of the weight of the Exige scoop that he created the mold from.
Now I just need to get to work on getting the rest of my fins / slats off the car :crazyeyes
I think you did the right thing starting there, but I'm just hoping there's a wider version next.
The current offerings look very nice, well made and all, but I agree a simple cost effective solution is highly desirable.
Discussion Starter · #14 ·
Also they performed great during a torrential downpour here in Chicagoland last night; I couldn't drive any faster than 60mph on I-80 on the way home or else I started to skid a little.
After the rain was over I drove a little faster than the speed limit *ahem* to test the forces on the scoops. Everything is tight as can be. Paint is as pretty as ever, and I'm excited for some "picture time" with the car later :)
likes to drive fast
Looking good! So the mod is reversible w/o leaving any marks?
Discussion Starter · #16 ·
100%. I removed the fins and installed these scoops with nothing more than a socket wrench and Phillips screw driver. That was the reason Chuck came up with these brackets that are light + hidden. They "grip" the inside of the rear clam and are in tension through the screws + inside bolts. Props again to Chuck for making a great design! :clap:
Great work! Did you actually make a scoop that is taller and can cover the edge trim on the rear clam?
You must cover the scoops with starshield or equivalent. Chuck's great paint job on the leading edge of the scoop will be destroyed. Trust me, I've been through this with my own creative install.
Also, is there a source for a larger mesh. I have mesh on the front and sides of my car, but would like to find a nice large hex pattern (see lamborghini gallardo Lamborghini (5)) and Lamborghini (6). The thickness looks nice, as it obviously isn't chicken wire.
Discussion Starter · #19 ·
Yeah I would definitely agree, as there are definitely a few specks on the lower trailing edge from the drive back from Chicago (rough storm + gravel = not good). I have since taken them off, dabbed some touch-up paint on and covered them in chufforia's stuff, but it's definitely not the same :mad: I'll see how much it bothers me and maybe have them resprayed when I get some other stuff done.
I believe Chuck used the OEM mesh; interested to see if there are other options, though it may not match the rest of the mesh on the car. The Lambo's appears to be some type of plastic? Anyone confirm? Maybe someone at a dealership?
i installed clear bra on the leading edge of the scoop.i also installed a 2 inch strip on the door and covered the tear drop portion of the body on the inside of the scoop.from what i read in wiskeys thread is the stones are drawn in from the air flowing down the side of the car.so they will also hit the door.i have the more open mesh grills in stock if anyone wants them.i havent looked into a bigger pattern yet.i believe my supplier has it though.
1 - 20 of 25 Posts
