1 - 17 of 17 Posts
2007 Lotus Exige S
I'm the proud new owner of this 2007 Exige S, purchased from @Car-chitect!
I hope to do most maintenance myself, so here's to the immeasurable learning curve ahead! Cheers all.
:UK:
Wow, that's incredibly sharp. Congratulations on the acquisition!
Good for you.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
For street cars, consider removing one or both oil coolers. Some cover them.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
You're local. I think there are more Exige owners in this area than most, but I still rarely see one. I remember when mine was stock. Have fun!
San
2007 Lotus Exige S
San
Thanks, San! I’ll be keeping an eye out for ya!
Congrats!
Welcome to the world of Lotus. So, just you can't say you were never warned... There's no return, there's no cure and you'll never, ever see the world the same again. <img src="https://www.lotustalk.com/forums/images/smilies/smile.gif" border="0" alt="" title="Smilie" class="inlineimg" />
Cheers,
Kiyoshi
P.S. Be sure to check out and join the LCOSC - Lotus Club of Southern California ? The #1 club for year 'round Lotus drivers.
Ha, I can only imagine. Appreciate the LCOSC link - hadn’t known about the group. Will definitely try to get to some of the upcoming events.
shay2nak
Congrats!
Congrats. Looks real nice. Drive safe and enjoy!
Love the Exige in all black..beautiful. Welcome to the forum.
2007 Lotus Exige S
Discussion Starter #16
1 - 17 of 17 Posts
