1 - 11 of 11 Posts
2007 Lotus Exige S Turbo
Hi everybody,
Matt here, happy to be joining the forum! I've had some fun cars in the past, including a 2007 BRG Mini Cooper S, a 2012 WRX Hatchback, and most recently a great AP1 S2000 that served mostly track duty.
After a long search, I've just picked up my first Lotus, a salvage title 2006 Exige with just over 40k miles. I bought it at as a bit of a mystery, after it sat in storage for 5 or 6 years, at a price low enough that I couldn't say no. It is my goal to return it to it's deserved glory.
It retains the original albeit repaired clams. It is turbocharged, running on an archaic Hydra Nemesis standalone, and there are mystery wires hanging out in the cabin with no indicator of what purpose they might serve. The car has many quirks, for instance the previous owner seems to have deleted the front fog/indicator lights and patched the holes in the shell (couldn't possibly tell you why). The gas gauge reads empty no matter the fuel level, there's a master killswitch installed that serves an additional purpose as the only way to turn off the grille-installed fog lights (which are apparently wired without a switch), and the shifter has enough play in it to rival an elementary school lunchtime recess. There seems to be a variety of custom work on the car, ranging from incredibly well done to shade tree-special.
Despite all that, after an oil change, coolant flush, and new spark plugs, she
is miraculously mechanically sound from a meta standpoint. I took her over to Evans Tuning yesterday, and after working through various snags (for instance, neither of the installed widebands were being picked up by the ECU), Jeff had it running great. We had 0 mechanical issues on the dyno, though for some reason that neither of us could figure out, she's stuck at ~6800rpm in every gear, as if it is stuck in launch control mode. Despite that, she still made a very respectable 325whp at ~6800rpm in 100deg ambient temp and 70% humidity. Here's to hoping the motor is built.
Next step will be yanking the custom wiring harness and obsolete ECU for a stock wiring harness (which the previous owner included) and a plug-n-play ECU alternative (looking at Monkey Wrench's, any suggestions?).
After sorting the ECU, improving the shifter with Stan's mod and a gated plate, and flushing the trans fluid, I plan on enjoying the car as-is for the brief remaining good weather window we have left here in NY, and the winter will bring a total overhaul of all any and all items that need attention.
I would love to hear if anyone knows the history of this car. It carries a salvage title from Nevada, though Jeff thinks he may have tuned it for a previous owner around 5-6 years ago. I've included pictures as well, and I believe it was black from the factory.
I look forward to learning from this community and bringing this lotus back to the road/track!
Wingless Wonder
1988 Esprit Turbo
Hi Matt,
I tried to post a reply earlier, but you VANISHED! Awaiting Moderator approval due to that outstretched tongue picture, before??? :ROFLMAO:
Anyway WELCOME to LT! I suggest you subscribe to LotusPALS, where NYC area Lotus events and gatherings are posted.
And if you want to join other Lotus track-junkies, Got Track Motorsports hosts HPDEs at the NYST (New York Safety Track in Jefferson, NY).
See you around!
Hi Matt,
See you around!
He was in the approval queue, but it had nothing to do with any pics, just the quirkiness of this forum.
San
Hey Carbuff! Lol, I wish the picture was me, it was a buddy at the Nurburgring a while back that I accidentally uploaded.
I’ll definitely subscribe! I recently did a day at NYST with the Classic Car Club of Manhattan in a Spec Miata, such a fun track. They have an Evora 400 as well that I’ve been itching to drive.
I look forward to meeting the other NY based lotus guys soon!
Good for you.
Lots of fun ahead.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
Good for you.
Lots of fun ahead.
5. Transmission:
And, use:
How to Bleed Brakes
How to Search:
Thank you GLB! I had seen this copied on some other posts, I appreciate you taking the time to add it here. I'll be working my way through the uberpost, and the shifter stiffening mods are high on my to-do list. Greatly appreciated!
Entirely my pleasure.
Welcome to the forum, Matt! That's a fantastic ride you got there. Can't stop looking at it for a whole 5 minutes.
Thank you Vinnie! I'm glad you like it. The orange wheels aren't entirely my type, but they're growing on me.
I'm playing with the idea of a JPS theme (big fan as my username might give away), with gold wheels, gas flap, and gold lotus lettering on the rear. There was an Elise 72D for sale near me that I missed out on, and I loved the look.
Administrator
2010 Exige S260
Hey Matt welcome, I am also located in Westchester, PM me if I can be of any help.
Discussion Starter #10
Thanks Kubera! Who do you trust in our area to work on your car? I’ve already been over to meet Waldir at Intermecanica in Mamaroneck, but haven’t met anyone who has worked with him in the past.
1 - 11 of 11 Posts
